head lights
HI all I have a wrangler 2007 x and want to change to the brite lights, I know the front grill has to come off but after that do I have to change the whole dome or do I have to change the bulb element on the inside. I will also being doing the fog lights are they the same way or are they drifferent, Thanks in advance
Bill
Bill
Twist the assembly until the bulb comes out, then pry the tabs up a bit and the bulb will come off the loop.
Are you going to replace them with Silverstars?
Whatever you do, make sure you do not touch the bulbs with your fingers. Any oils or contaminants could bust the bulb when lit and you'd be out a lot of $$$.
I put Silverstars on my 08, no problem. i didn't remove the plastic grill, I just moved the air box out of the way and the power steering reservoir on passenger side. Driver side just moved the horn out of the way. Plugged the Silverstars right in. Big difference on brightness!
I think I might have to adjust the factory settings alittle, other than that a easy upgrade.
I plan on replacing all my lights with Silverstar's as well... however at $20 bucks a pop, that's $80 bucks I gotta shell out... on just bulbs, lol.
My old Ford Focus had HID lights stock. I miss those beautiful headlights. I'm hoping the Silverstars will look better than the dull yellowish stock bulbs.
Hi all I just replaced the stock with silver star bulbs I did both head lamps and fog lights..real easy job here are the number bulbs for a jeep wrangler 2007 X
Head H13st
Fog 9145ST
Bill
Head H13st
Fog 9145ST
Bill
