Headlights.
My 2012 JK has a issue wth blowing out headlights. It does have a Rally light harness, so the lights run off the battery. It does make them much brighter, but with the high voltage that my JK puts out when running might be the issue. It has always done this, and the stealership said it was in spec. I was wondering if any one is running LED bulbs. Not LED headlights, just the bulbs. I am not going to spend that kind of money on Headlight for a JK. I might for one of my Real Cherokees, but not for the WRONGLER.
Perfect answer.I'm curious how many pairs of garbage bulbs you're willing to buy before you buy a nice set of headlights and be done with it?
Also curious, what's the difference between a Real Cherokee and a not real Cherokee?
OK so I take it the LED bulbs are not a good idea. I did buy a 94 2dr XJ to replace the JK. Just going to put a lift on her with tires and gears. I really don't want to spend any more big dollars on the JK. I thought I wanted a new vehicle, but I was wrong. Too many electronic glitches over the few years I have owned it.
Probably the only way to make things work properly will be truck lights/JW or HID projector system. Don't think there is a cheap way around it. I dive mine daily so it's worth it being able to see in the dark.
The problem with throwing a random LED into the factory housing is that the reflectors aren't designed to disperse the light for an LED light, and that is crucial to getting the benefit of one.
Any input would be great.
I ran the IPF H4's on my last JK, and the were a nice inexpensive upgrade for a non LED light, and still had a nice white light color.
