Help with adjusting Bilstein streering stabilizer
Old May 9, 2013 | 03:45 AM
LeeperJeeper's Avatar
Default Help with adjusting Bilstein streering stabilizer
I recently put an AEV 2.5" lift on my 12 JKU and thought since I got the Bilstein shocks with the lift I would get the steering stabilizer to match. It now steers to the left. How do I adjust it to eliminate it steering to the left?
Old May 9, 2013 | 03:53 AM
tribulation138's Avatar
I think the stabilizer piston should be facing the right side? Is that how yours is?
Old May 9, 2013 | 03:54 AM
aldaman's Avatar
Others have ran a dual stabilizer set up to counter the pull to one side...
Old May 9, 2013 | 04:07 AM
I have the cylinder mounted on the passenger side. With my current sent I think dual steering stabilizers would be too much.
Old May 9, 2013 | 04:22 AM
hooper's Avatar
My Fox stab. does the same. You will get used to it.
Old May 9, 2013 | 04:42 AM
ballistik_monkey's Avatar
seriously? i didnt know this. hmmmmm....
nevermind. woke up from my food coma and realized...that is how mine is lol.
Old May 9, 2013 | 05:10 AM
MMXJKU's Avatar
Put the stock stabilizer back on.
Old May 9, 2013 | 05:28 AM
jeeeep's Avatar
there's a write-up on here and teraflex has a video about installing and adjusting your SS - all you really need is the stock unit.
Old May 9, 2013 | 05:34 AM
Rubi_Matador's Avatar
Go full wheel lock in either direction and either fully compress or extended the stabilizer accordingly.
Old May 9, 2013 | 05:48 AM
raycn's Avatar
I reviewed the threads talking about steering stabilizers before buying my Old Man Emu. I also have bilsteins but did not go with the Bilstein SS because of the issue with it pulling to the left. The OME has had no issues.
