Help with adjusting Bilstein streering stabilizer
To avoid the "pull" from aftermarket SS; I went and forked over the cash for the new FOX ATS SS. I think you are going to have to get use to it, or not use it if the pull bothers you too much. Good luck.
I just installed the dual Bilsteins because of the push/pull of the single set up.
You will get rid of the issue if you install two of them as the push/pull is counter acted by two units working against each other.
Mine works perfectly!
I put the Bilstein ss on with the lift. Then I tried adjusting it to eliminate the steering to the left. It was suggested the putting the stock ss would fix the problem. I did so last night and still have the problem.
I centered the axles, did the alignment using the write-up and since this was the 1st time doing my own alignment, I took it to an alignment shop that understood Jeeps and larger tires (they should not be aligned to oem specs), everything checked out fine
