HELP! Bad Steering Clink Noise (video link in post)
Hey all,
I live in NJ and pot holes suck. I recently discovered my Rough Country Dual Stabilizer took a huge hit from something and shifted everything. I took it to my lift guy Mike at Baker Jeep here in Princeton. He's the one who installed it and came to the conclusion that something must have hit the stabilizer kit cause its whacked and there is a dent in the BACK of one of the stabilizers. Doesn't matter what hit it but here is my issue...
I noticed a significant turn radius difference. It turns nice and sharp to the left. But when I turn right, its almost as bad as a large truck. So I knew something was off and discovered my stabilizer issue. I'm getting a new kit on next week cause its cheap, but he is also going to look into a solution to make sure it doesn't shift.
LAST NIGHT when I was driving this started and I took this video when I parked.
https://www.youtube.com/watch?v=QvAmoN--SO4
I have no idea what it is, but its steering related AND its not coming from the stabilizer or anywhere near it. It sounded like its coming from something else in the steering realm...any ideas experts??
Other than the noise and lack of turn radius, everything great on my JK
Hey, thanks for taking a look! appreciate that. It was snowing and 20 degrees when I took the video, haha. I tried my best. However, my JK has 16K miles on it...warn out!!! that scares me. But thanks for the point of reference!
Things ware out faster with bigger tires and weight. That's why it's important to upgrade certain parts prior to just throwing let's say 37s on all factory components. Now I'm not starting can you run 37s bs. Yes yes you can. Just a simple response to having bigger heavy things require other bigger heavier things. Driving style has a lot to do with it als
Along the lines of Smudge's comment above, I've had a near identical sound twice now where the culprit was a slightly under-torqued TB bolt axle side. In my situation I use Fluid Film on my axle side TB joint....it was penetrating the threads and causing that bolt to start working loose. It didn't have to be under-torqued by much to start creating a popping sound very similar to that. I now use threadlock on that bolt.
Have some else turn the wheel back and forth while you put your hand on the dragline, track bar, tie rod, etc and you'll figure out where the play is coming from by feel if u can't locate it by sound.
