Help with BB ride
Old Mar 15, 2011 | 04:08 PM
Battlefrog's Avatar
Typo: shocks and coils...
Old Mar 15, 2011 | 04:23 PM
Battlefrog's Avatar
If the bumpstop is put on backwards then the cup could get caught under the lip of the plastic "add-able" bumpstop. The actual foam piece will slide right past the bumpstop and the retainer will get caught, lol- I saw this firsthand.
I think the spacer and isolater combo is a more viable problem because anyone would notice the rear suspension not cycling at all with the bumpstops caught.
If I recall correctly, we put mine on backwards and switched them around because it's extremely noticeable when you connect the axle back up.... Lol
Old Mar 15, 2011 | 06:46 PM
Battlefrog's Avatar
That is correct, but that is the only way I can see the bumpstop getting caught and causing the axle to get stuck in the down position.
Still no pics??????
If it's traveling that far from normal DD, then their is a bigger issue than a simple BB lift....
Old Mar 15, 2011 | 06:52 PM
RAINSTATEBEAR's Avatar
My bumpstops were on backwards, and the passengers side kept geting hit by the bolt head of the track bar if memory serves me corret. Everytime I hit a bump, though I was bottoming out. Turned them around and all is well.
Old Mar 15, 2011 | 06:53 PM
Battlefrog's Avatar
Maybe I stand corrected...
