help! cant get enough droop to remove spring.
I searched every single thread about installing front spacers before I started. I don't have a spring compressor so I'm doing it per the teraflex directions and the way others have. I don't know what to do about the brake lines to get more droop.
-unbolted the brake line bracket from the frame.
-unbolted the brake line bracket from the axle, you also have to remove that bracket from the axle
-unhook the ABS line from the hub (2ea)
-remove the breather hose from the differential side.
-If you have a Rubi, be careful as you lower the axle because you may over stretch the locker wire/line at the differential.
Good luck. Keep us updated.
I breezed through the other front spacer, and pretty good on the drivers rear - got stuck for hours on the pass rear...ugg will post about the horrible experience in another thread!
