help! cant get enough droop to remove spring.
Old May 12, 2012 | 07:29 AM
G DIESEL's Avatar
Default help! cant get enough droop to remove spring.
My brake lines are tight and still can't get enough droop to remove the front spring. What am I doing wrong here? The sway link is disconnected and the bottom of the shock. I can droop it more but the brakes lines are at the limit.
Old May 12, 2012 | 07:32 AM
Running Man's Avatar
Looks like you need to unbolt it from the frame! It's the silver bracket with one bolt.... 8 or 10mm I believe.
Old May 12, 2012 | 07:34 AM
G DIESEL's Avatar
I searched every single thread about installing front spacers before I started. I don't have a spring compressor so I'm doing it per the teraflex directions and the way others have. I don't know what to do about the brake lines to get more droop.
Old May 12, 2012 | 07:35 AM
carolinajk's Avatar
unbolt brake line retainer and abs line retainer you may have to pry down with a large bar jus make sure your lines arent strained mine was the same way also be careful underneath there
G DIESEL's Avatar
Ok, that will give me more slack?
Old May 12, 2012 | 07:36 AM
Yes!!!!!!!!!
Old May 12, 2012 | 07:44 AM
G DIESEL's Avatar
Thanks everyone going out to take another try at it.
Old May 12, 2012 | 08:08 AM
G DIESEL's Avatar
That was the best tip, never mentioned in the instructions or the threads I read gave me plenty of room to get out the spring. Thanks again.
Old May 12, 2012 | 08:16 AM
aldaman's Avatar
I just recently installed 1" TF spacers to level the Jeep. The springs came out W/out the need to use spring compressors. Aside from what you mentioned already I also:
-unbolted the brake line bracket from the frame.
-unbolted the brake line bracket from the axle, you also have to remove that bracket from the axle
-unhook the ABS line from the hub (2ea)
-remove the breather hose from the differential side.
-If you have a Rubi, be careful as you lower the axle because you may over stretch the locker wire/line at the differential.
Good luck. Keep us updated.
Old May 13, 2012 | 01:53 AM
G DIESEL's Avatar
I breezed through the other front spacer, and pretty good on the drivers rear - got stuck for hours on the pass rear...ugg will post about the horrible experience in another thread!
