Help with correcting castor angle needed
Old Nov 5, 2012 | 08:27 PM
Rooster454's Avatar
Default Help with correcting castor angle needed
My front LCA's should be here Wednesday and I am curious as to what angle I need to get rid of the flightiness. I realize some trial and error is needed to get it perfect, but any starting point would be very helpful.
I netted right at 4" of lift so I'm not sure what length might help me correct the angles.
Any help is appreciated.
Thanks
Old Nov 5, 2012 | 08:44 PM
Freewill's Avatar
The angle is in the range of 4 to 6 degrees, depending on where the steering feels right and the pinion angle looks right. Its a compromise.
Not sure of the length for 4" of lift.
Old Nov 6, 2012 | 04:29 AM
Rooster454's Avatar
Got it. I thought that was the right range, but wasn't 100% sure.
Thanks boss
Old Nov 6, 2012 | 05:18 AM
Bonedoc's Avatar
The more positive caster you have the more stable and better your JK will handle, but the moe you increase the caster the more you increase your pinion angle. Basically it is a balance between as much positive caster as you can get without creating a driveline issue, most notably a driveline vibration because of too steep an angle.
I have Trailmaster's 4.5" lift. My caster is +5.25-5.5 degrees. Handles very well, minimal flightyness and no driveline vibrations. Call your lift manufacturer, their tech dept. will likely have a number that will be either a good starting point or the number to be aiming for, for your particular lift.
Old Nov 6, 2012 | 10:55 AM
Rooster454's Avatar
Good info, thanks. Unfortunately I have a multi piece lift. I started with the Teraflex 2.5" and just added 1.5" aluminum coil spacers to give me just enough room to clear 37's while retaining my comfortable ride and lower center of gravity.
I'll call and see what they say. Thanks
Old Nov 6, 2012 | 11:23 AM
kny21's Avatar
Where are you guys measuring your caster from? I have a dial gauge but not sure if I should trust using the upper C on the axle or somewhere else to get this spec???
