HELP!! Death Wobble
Old Dec 15, 2012 | 09:58 AM
JKJeepJunkie's Avatar
Default HELP!! Death Wobble
So I have an 08 Jeep 2 door JK and it had the stock ugly steel sport rims on it with chrome hub caps and 225/70/r16. I replaced them with 17" rubi wheels and 255/75/r17 tires now I have the death wobble if I hit a bump at 50mph please tell me how to fix this it scared the crap out of me o the freeway the other day and I don't want my wife driving it like this either
Old Dec 15, 2012 | 10:04 AM
Robert.frederick's Avatar
Did you have the tires balanced?
Old Dec 15, 2012 | 10:12 AM
I bought the tires from a guy on craigslist they have weights on them so I guess there balanced I'm not sure can that really cause my Jk to go crazy like that
Old Dec 15, 2012 | 10:33 AM
Edge Hawk's Avatar
wheels out of balance can cause a shimmy. (I have some mud in my wheels right now that's causing a little bit)
Now shimmy and death wobble are 2 different things. Do you have to come to a complete stop before the DW stops? Also, are your lug nuts all tight to specs?
Old Dec 15, 2012 | 11:43 AM
Smashboogie 4x4's Avatar
Former Vendor
Switch back to your other wheels and see if it still happens.
It could just be a coincidence that you are noticing it after you changed to the Rubi wheels.
Old Dec 15, 2012 | 12:25 PM
Lugs are all tight and and this is more than a shimmy it shakes my whole jeep I have to slow down to about 10mph for it to stop and then I can get back up to speed, I'll put it this way I had my phone in the tray on top of the radio and it somehow ended up between the passenger seat and the door
Old Dec 15, 2012 | 12:27 PM
No if it did this before I would have definitely noticed it when it happens it almost pulls you off the road
Old Dec 15, 2012 | 01:08 PM
Former Vendor
I would reinstall your original wheels and see if it happens or not. This will eliminate the wheel as being the problem or not. If it does do it when you do reinstall your original wheels then you know you have a problem with the Jeep. If it does not do it once you have reinstalled your original wheels then you know that the Rubi wheels are the problem.
I had this happen when I broke my rear lower shock mount.
Old Dec 16, 2012 | 03:36 PM
I just changed my stabilizer today with a rancho rs5000 and its still happening it did get a little better though
Old Dec 16, 2012 | 03:43 PM
keithvegas's Avatar
An off balance tire can initiate DW but are not the cause. A steering stabilizer will only mask it. You most likely have a loose track bar or another loose or worn part in your front end.
