Help with EVO protek skid...
Old May 2, 2013 | 11:20 AM
lulu2533's Avatar
Default Help with EVO protek skid...
Have all the skids installed except I'm having extreme difficulty lining up the last bolt on the exhaust/tranny skid. They all line up except for this one. It's the one on the driver side that bolts into the frame. Don't know if I boogered something up last time at Rausch to make it not want to go back in or what. Any suggestions??
Old May 2, 2013 | 11:22 AM
Northridge4x4's Avatar
Sponsoring Vendor
All the other bolts still loose?
David
Old May 2, 2013 | 11:34 AM
lulu2533's Avatar
I loosened all the others and put that one in but then one of the others wouldn't line up... Not sure what's going on. I know I have the right skids...
ID:	453511Click image for larger version
Not the best pics
Old May 2, 2013 | 11:41 AM
ilikeguns's Avatar
Recently I put these on a friend's jeep and had to barely thread all the bolts, then go back again and start cranking them down. Do you have exhaust spacers installed? Is anything else preventing the skids from sitting flush?
Old May 2, 2013 | 11:57 AM
lulu2533's Avatar
Nope, no exhaust spacers. I guess I'll try loosening them again and try barely treading them like you said. If worse comes to worse I guess I'll take her to an offroad shop and see if they can do anything. Thanks for the suggestion.
Old May 4, 2013 | 04:52 PM
ilikeguns's Avatar
Any luck with that?
Old May 4, 2013 | 04:56 PM
jeeperjkjeeper's Avatar
can't you just ream that hole open a bit for clearance?
Old May 4, 2013 | 05:06 PM
ScruffyRubicon's Avatar
I had to put that side on first. This caused the bolt on the other side to not line up entirely at the fuel skid hole. With a small pry bar, I was able to get that side to line up.
I'm also not running a spacer.
Old May 5, 2013 | 03:25 AM
lulu2533's Avatar
Didn't get a chance to do anything yet. Thanks for the input everyone.
Old May 5, 2013 | 12:12 PM
Denny2565's Avatar
I had to ream out a couple holes to make mine fit.
