Help a girl out!!
Old Aug 7, 2015 | 03:58 PM
Jkx1113's Avatar
Default Help a girl out!!
About two weeks ago my dad and I put in a teraflex leveling kit and 1.5" wheel spacers on my stock 2008 jeep jk wrangler. Was I suppose to replace or change something else? Because now there is a strange noise from my front left tire when I turn the jeep to the right. It's almost done like a tension noise...I really wish I knew how to explain it better....I've had an alignment and tire rotation and the noise is still there.... I wish I knew more about the mechanics of the jeep...I'm learning as I go! Thanks for your help!
Old Aug 7, 2015 | 04:30 PM
unlimited12's Avatar
did you remove the rotor retaining clips before you put the spacers on? check and make sure that everything is tight
Old Aug 7, 2015 | 04:32 PM
DJ1's Avatar
DJ1
Former Member
Yeah I would double-check the spacers (re-torque/tighten) and make sure those clips are off first...
Old Aug 7, 2015 | 04:39 PM
Jkx1113's Avatar
I'm going to go with no on this because I don't remember removing anything before we put on the spacers...
Jkx1113's Avatar
I'll be doing that tomorrow
Old Aug 7, 2015 | 04:57 PM
Albino Lizard's Avatar
A photo for reference.
Old Aug 7, 2015 | 05:00 PM
I doubt that clip is making a noise. Check your track bar for proper torque. If you didnt use a torque wrench on everything there is the potential for all kinds of problems.
Old Aug 7, 2015 | 05:03 PM
true but if the clips are still on they won't allow the spacer to sit flush with the rotor and tight
Old Aug 7, 2015 | 05:45 PM
nthinuf's Avatar
Stuck right to the top of this modified area is a good thread on general lift info. And if you go up to JK Writeups, stuck right to the top is a good thread on diagnosing dw/shimmy. (there is a great picture of the frontend components in this one). Reading those might be a good way to waste a few minutes.
The noise happens every time you turn right? Only at certain speeds? Only while turning and hitting a dip or bump? What size tires are you running? Could they be rubbing on right turns? Or maybe a ujoint going bad? Unit bearing? Loose tire? Hard to say without a better description, we'll all just be guessing...
Old Aug 7, 2015 | 06:40 PM
RubiKing's Avatar
Check everything you unconnected to install the leveling kit. Maybe a loose sway bar end link or a loose shock bolt.
