Help a girl out!!
Old Aug 8, 2015 | 03:30 AM
Run2Ga's Avatar
Did you change tires too? If so, maybe rubbing on the air dam?
Old Aug 8, 2015 | 01:07 PM
Jkx1113's Avatar
Originally Posted by nthinuf
Stuck right to the top of this modified area is a good thread on general lift info. And if you go up to JK Writeups, stuck right to the top is a good thread on diagnosing dw/shimmy. (there is a great picture of the frontend components in this one). Reading those might be a good way to waste a few minutes. The noise happens every time you turn right? Only at certain speeds? Only while turning and hitting a dip or bump? What size tires are you running? Could they be rubbing on right turns? Or maybe a ujoint going bad? Unit bearing? Loose tire? Hard to say without a better description, we'll all just be guessing...
I'm pretty sure it's only when I turn or veer right...it's made the noise relatively consistently at different speeds...the tires I have on don't seem to be rubbing...I checked that...I have a feeling it might be a joint or bearing going bad...along with the rotator retaining clips not allowing the spacer to be flush..thanks for your input! I'll be double checking all of these
Old Aug 8, 2015 | 01:08 PM
Jkx1113's Avatar
Originally Posted by RubiKing
Check everything you unconnected to install the leveling kit. Maybe a loose sway bar end link or a loose shock bolt.
Thanks I'll be checking everything!
Old Aug 9, 2015 | 02:01 AM
ItalianNut's Avatar
You may not have touch this item but if your track bar is not torqued to 125 pounds you will get a tension notice when turning. Just if you don't know. It's the bar with the bend in it, has a bolt and nut on each end. I just lifted mine and after driving it a notice started and it was the track bar. Good luck!
Old Aug 9, 2015 | 02:35 AM
101gargoyles's Avatar
Former Member
Help a boy out. I thought there was no difference anymore. Except no girl holds a door open when I'm walking up with my arms full. OH WAS THAT MY OUT-LOUD VOICE? sorry so sorry I'm just a man.....Was 'Help a girl out' as a title any less incorrect? Dad was helping And yah, install a lift check everything twice-dad's job
Old Aug 9, 2015 | 08:29 AM
OH9JK's Avatar
JK-Forum Ambassador
Old Aug 9, 2015 | 09:02 AM
CajunTiger's Avatar
If you go to your friendly Psychiatric center, I'm sure, no, I'm positive they will prescribe Xanax and anti-depressants for ya bro! Take a deep breath and relax....it gets better.....
Old Aug 10, 2015 | 02:46 PM
Jkx1113's Avatar
There is definitely tension, thanks!
Old Aug 10, 2015 | 02:48 PM
A.W.D.eLussey's Avatar
Originally Posted by Albino Lizard
I doubt that clip is making a noise. Check your track bar for proper torque. If you didnt use a torque wrench on everything there is the potential for all kinds of problems.
x2. Track bar needs to be torqued to spec. I think it's 65lbs.
Old Aug 10, 2015 | 02:57 PM
Mark Doiron's Avatar
125 ft-lbs. All four bolts (axle and frame, front and rear).
