HELP!!!! I dont know what to do!
Old Oct 20, 2008 | 08:48 AM
greengiant's Avatar
Default HELP!!!! I dont know what to do!
okay, i got a 08 2dr. its my DD, and im wanting to run 33s, and prolly the teraflex 2.5 BB. I dont know what all to order..ie rim size (best i can tell i should run a 16in with what backspacing??) , what size wheel spacers, is the teraflex a good option for me? if any of you guys are runnin this setup, pics would be nice! thank you much for your time...
Old Oct 20, 2008 | 08:55 AM
wayoflife's Avatar
JK-Forum Founder
the TF 2.5" BB is a very complete kit and it'll come with just about everything you need to run 33's. if there is one other component you should get, it would be an adjustable front track bar but even at that, it's not necessary. as far as wheels go, yup, a 16" or 17" wheel with 4.5" of back spacing or less is what you'll want
Old Oct 20, 2008 | 08:56 AM
AlmightyCrash's Avatar
with proper negative offset wheels, you wont need spacers at all.
and if you only want 33s, a bb would be all you need to ride a bit taller.
go look at the thread "show me your 33s", and see what others are running to get an idea of the look you want to achieve.
TeraFlex's Avatar
Sponsoring Manufacturer
4.5" backspacing or 1.25" wheelspacers (TeraFlex makes some).
Old Oct 20, 2008 | 11:40 AM
tgrt's Avatar
Former Vendor
What everyone said. A rim with 4.5" backspacing would be fine assuming the tires aren't too wide. The 16" rim will save you a little money. Personally I prefer the 17", it may not have any bearing in truth, but I feel it may provide the most flexibility later (for example, if they come up with some upgraded brake system down the road).
I think your Jeep will have a great stance from what you're proposing.
Old Oct 20, 2008 | 11:45 AM
JUS 1 MO's Avatar
I an running the same as you are looking at. I have the Teraflex 2.5" BB, 17X8 Pro Comp Wheels with 4.5" BS, and 295/70R17 Nitto Terra Grapplers. Works great.
Old Oct 20, 2008 | 01:04 PM
lijeepguy's Avatar
im running a Rough country 2.5 BB lift , and 33/12.5/17 dick cepeks with 4.75 bs and i have no issues at all , look at my pics, rims are 17x8.5x4.75 bsClick image for larger version
Old Oct 20, 2008 | 01:06 PM
muddpuppy01's Avatar
they do have upgrade kits out there but require you to run 20" wheels
Old Oct 20, 2008 | 02:29 PM
where can i find those brake upgrades?
Old Oct 20, 2008 | 04:25 PM
it was camp crooker and I dont know if burns did it also
https://www.jk-forum.com/forums/show...=big+brake+kit
