Help! - Installed 35's. cant get tyre pressure alert to turn off with ProCal
Old Mar 24, 2013 | 12:57 AM
eZa's Avatar
eZa
Default Help! - Installed 35's. cant get tyre pressure alert to turn off with ProCal
Hi,
I recently installed 35 inch BFG's on Pintlers.
The tires are at 35 PSI (which is well above the stock low PSI alert)
I used the ProCal to set my speedo etc.
I also used the ProCal to try to set my Low PSI warning to charm below 25 PSI.
I cannot seem to get that charm to turn off!!
Does anyone have some ideas on how to fix this?
Thanks
Old Mar 24, 2013 | 02:26 AM
aldaman's Avatar
Use the (0-15psi) setting. It worked for me. My tires are at 28psi. No chimes or (_!_) light...
Old Mar 24, 2013 | 02:50 AM
snowdog's Avatar
Stupid question, but did you move your stock TPMS sensors into your new wheels?
Old Mar 24, 2013 | 03:36 AM
eZa's Avatar
eZa
Well, I got new tires and wheels fitted at once. I have not touched the original wheels.
Did I need to put a device into the new wheels?
Old Mar 24, 2013 | 03:38 AM
eZa's Avatar
eZa
Ok I will try that. How do u find 28psi for daily driving?
Do u have 35/12.5/17 km2?
Old Mar 24, 2013 | 03:58 AM
MSmitty's Avatar
Umm.. yeah. Nothing you will do shy of turning the tpms off all together will get it working if you didnt have them swap out the sensors to the new wheels.
Old Mar 24, 2013 | 04:00 AM
DadsCJ's Avatar
If you didn't put in new sensors, that is your problem. It can't find the sensor and the alarm is on because of that.
You can turn off the alarm but you have to set the ProCal to off.
Old Mar 24, 2013 | 06:39 AM
Staytru06's Avatar
Set tpms to 0 and problem solved
Old Mar 24, 2013 | 11:29 AM
kgonzalez's Avatar
Mine took about a day and a half, but the light eventually went off. The guy at the tire place said it was common when changing pressure and threshold and it might take a day or 2 to settle out. I thought he was full of crap. But, turns out he was right in my case.
Old Mar 24, 2013 | 11:39 AM
hypeiv's Avatar
if you didn't move the sensors from your OEM wheels you need to set the procal to 0
