Help Me Fix My Problem
Old Apr 29, 2009 | 06:38 AM
Thanks for the reply you guys and I will go with the lower control arms and then take the trackbar off and see if its wallowed out any......I really dont want to throw a bunch of parts at it but i do want my steering tight and not flighty or shimmy alot. I understand its a jeep thing and i love it.
We will see what happens. I do want that monster track bar from from teraflex though
Old Apr 29, 2009 | 08:21 AM
aldaman's Avatar
Originally Posted by Warlock13
This is a problem i have been having for awhile. Like most people the lift goes on and then you get death wobble. Mine isnt death wobble evertime but it happens frequently
I check everything and all the trackbar and tie rod endings are tight as can be.
Aside from all the great recommendations. I just wanted to point out the obvious (dont know if you did or did not do this already) but it doesnt cost anything. Since you've checked the tightness of the track bar, was it installed & torqued to the proper specs with the full weight of the Jeep on the ground and not while it was jacked up? Best of luck in finding a remedy...Keep us posted..Thanks...
Old Apr 29, 2009 | 08:49 AM
Don't quite know the answer to that one so I will have to try that out.
Old Apr 29, 2009 | 08:58 AM
RedneckJeep's Avatar
Originally Posted by jkkat
You might want to unbolt your stock track bar and see if the rubber parts are showing wear or looking egg shaped instead of being tight around the pipe that goes through.
Advice comin from somebody that can't even keep all their wheels on the ground??? Puleeeze.
Old Apr 29, 2009 | 09:22 AM
Hahahah I guess i should post this picture up then.......
THis is a picture of my trackbar connecting to the drop pitman arm. ( I DO BELIEVE correct me if im wrong)
Old Apr 29, 2009 | 09:29 AM
greenamphibious's Avatar
if you trac bar is connected to the pitman arm you are in deep doo doo!
Old Apr 29, 2009 | 09:42 AM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
thats funny
anyway, that is your draglink that connects to the pitman arm, here read and look at this pic
http://project-jk.com/jeep-jk-write-...-end-alignment
Old Apr 29, 2009 | 09:50 AM
eDiveBuddy's Avatar
I see the tie rod end boot on your drag link it torn. Is there any play there?
Old Apr 29, 2009 | 09:52 AM
Originally Posted by tkob1060
thats funny
ah that's the pic I was looking for
Old Apr 29, 2009 | 10:01 AM
I knew it was one or the other LOL!!!! Thanks for clearing that up toad. Well ya the boot is torn on the drag link in the picture but the tracbar dosent look like it has anything wrong. I will have to take it off and see if its wallowed out.
