Help needed!!!
Old Dec 5, 2009 | 03:23 PM
Speedboy's Avatar
Default Help needed!!!
Hi Everyone
I am in need of assistant. I just installed a 4" Rough Country lift and the Dual stabilizers took in for a test run and the steering seem to be very off. And I am getting a traction error. PLEASE HELP! Thanks
Old Dec 5, 2009 | 03:34 PM
fullthrottle's Avatar
did you re center your steering wheel
Old Dec 5, 2009 | 03:55 PM
Speedboy's Avatar
What do you mean?
Old Dec 5, 2009 | 04:00 PM
Monty-'s Avatar
you likely need to center your steering wheel. check the write ups for the details.
http://project-jk.com/jeep-jk-write-...-end-alignment
Old Dec 5, 2009 | 04:02 PM
ricrac12525's Avatar
x2
Old Dec 5, 2009 | 04:15 PM
Speedboy's Avatar
Is that the Draglink?
Old Dec 5, 2009 | 04:17 PM
BlackNorthernJK's Avatar
you recenter the steering by adjusting the drag link yes
Old Dec 5, 2009 | 04:20 PM
nthinuf's Avatar
Open the link
Click on the pic in the upper left corner (save it somewhere for quick reference...) The drag link is outlined in a purpley color. And it even says something 'drag link', with an arrow pointing at the, you guessed it, drag link...
Read the "Re-centering Your Steering Wheel " section. Loosen bolts, twist, check steering wheel, twist more, check steering wheel, etc... Tighten bolts. Done
Old Dec 5, 2009 | 04:34 PM
Speedboy's Avatar
alright thank you and thank you for the sarcasm
Old Dec 5, 2009 | 04:49 PM
Monty-'s Avatar
maybe i missed it but where was the sarcasim? you've got some on here trying to help you out. also, i don't know anything about the kit you bought but hopefully it had something included to address the castor issues with 4" of lift. without it, your jeep will drive funky.
