Help with post lift problems
Old Feb 22, 2013 | 08:47 AM
  #21
chris@offroadevolution's Avatar
Sponsoring Vendor
Originally Posted by enash965
Ok cool. Thanks a lot. I talked to a few other guys and most are recommending the JKS rear upper and front lower adjustable control arms. When you install these how do you know which is the correct caster adjustment to help take the stress off my drive shaft? Another questions is I installed the shocks that came along w/ the lift....not sure how good they actually are. Would you recommend going w/ a better shock brand for a nicer ride? I am going to order the front lower and rear upper control ARMS probably today or tomorrow.
I believe JKS has discontinued the control arms. you will need to set your caster at 4.5 degrees or a little more
Here's a good write up
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Old Feb 22, 2013 | 09:02 AM
  #22
enash965's Avatar
Search Results - Quadratec
Heres some I found on quadratec of adjustable control arms. Probably will order some by monday. Ill send you a message if I have any other questions if thats cool with you. Thanks for the help! THe JK world is new to me.
Old Feb 22, 2013 | 10:06 AM
  #23
enash965's Avatar
I have to go to military training this weekend an need to drive on the high way about an hour and a half today and an hour and a half Sunday. Think ill be good to drive it without hurting anything?
Old Feb 22, 2013 | 12:05 PM
  #24
Sponsoring Vendor
Perfectly fine, Theres nothing wrong with your lift. It just wont drive as nice as it can that all.
Old Feb 22, 2013 | 12:07 PM
  #25
enash965's Avatar
Ok. Thanks again I really appreciate all your help.
