Help!! with Rims
Old Apr 19, 2010 | 08:06 PM
szqnva's Avatar
Default Help!! with Rims
Hi! I'm a newbie with a 2010 Sahara Unlimited. Getting ready to head to shop on Monday to get 3" lift w/ Nitto Trail Grapplers and EAgle 140's. But...in googling for some eagle info, I ran across a post advising that they're not designed for jk's. Now I'm totally confused. Need some advice. Anywhere that I can go that will recommend specific rims for my vehicle? Thanks!
Old Apr 19, 2010 | 08:08 PM
spinlock's Avatar
Start by reading the FAQ in this section. As long as the rims meet the diameter, bolt pattern and backspacing requirements you are good to go.
Old Apr 20, 2010 | 03:23 AM
crcjk's Avatar
Default Re: Help!! with Rims
As I understand, the only wheels made specifically for the JK are the AEVs. Not sure how much differeence the hubcentric design makes.
Sent from my Droid using Tapatalk
Old Apr 20, 2010 | 04:16 AM
szqnva's Avatar
Thanks. Honestly...I know very little about this stuff, so even some of the "faqs" are greek to me. I guess I'll just trust that the shop I'm using knows their stuff. And in the meantime, I'll just keep reading.
Old Apr 20, 2010 | 06:35 AM
IcyFridge's Avatar
X2 on what plan man said. I would go with 16 inch wheels. the 15 inch wheels are a hit n' miss with the brake calipers on the JK.
You're getting a 3 inch lift, so why not get 315/75R16 (34.5x12.3) Nittos on 16x8 Eagle 140 rims with rims with 4.517" of backspacing?
Rims: part number 1402-7850 (color is your preference)
I am not 100% accurate on the part number - I just grabbed it from
http://www.aewheel.com/wheels_detail_specs.cfm?id=356
Old Apr 20, 2010 | 01:55 PM
szqnva's Avatar
Originally Posted by planman
You want a 5x5 bolt pattern, 4.5" or less backspacing, & an 8" wide wheel.
If you run 15" wheels, you want 4" or less backspacing.
What about this is "Greek"?
"Greek" in the sense that I know absolutely nothing about tires, wheels, or pretty much anything automotive. Example: backspacing - but I'm not asking for an explanation. I'm a little embarrassed that I even asked my original question. Might be better if I just attempt to learn a little bit more first. Thanks for the info, though. Every little bit helps.
Old Apr 20, 2010 | 02:00 PM
szqnva's Avatar
Right now, we're scheduled to get "17x8 machined 5 on 5". I'm reading this off the receipt, so sorry for the lack of detail. And 35x1250x17 Nittos. Should that work?
Old Apr 20, 2010 | 02:22 PM
JayhawkJeep's Avatar
Veteran: Navy
Would check on the back spacing. This describes it way better then I ever could:
https://www.jk-forum.com/forums/show...274#post211274
Old Apr 20, 2010 | 02:53 PM
szqnva's Avatar
Thanks so much! I admit...I'm clueless. But hopefully I'll figure all this stuff out eventually.
Old Apr 20, 2010 | 03:00 PM
IcyFridge's Avatar
I checked the same websit that I got the 16x8 rims off of. The 17x8 with the 5x5 uses a 4.517 backspacing and it should be fine with 35x12.50R17 tires.
