help in shock
Old Apr 4, 2008 | 09:32 AM
bahadden's Avatar
Default help in shock
what is the col/ ext lenth of the stock shock vs an aftermarket 3 inch shock. anyone have the measurements of stock? wantinto up grade from the shock extenders i am running.
Old Apr 4, 2008 | 09:39 AM
MAROONJEEP's Avatar
call david at northridge 4x4.
Old Apr 4, 2008 | 10:07 AM
TEEJ's Avatar
Talking
It varies by maker and lift options......not all 3" lift kits use the same sized shocks....pretty large variation actually.
I've seen 15-24" up to 16-28" versions for a 3" lift.
I'd get something around 15-27/28", dependant upon your willingness to unclip and reposition the e-brake cable, brake wires and lines, etc...so as to LET the suspension USE the extra travel (Free mods). Past about a 27" shock...you have a lot of travel, and you need to make other compensations to stretch it further, but still have the ability to stuff tires as need for stability.
Old Apr 4, 2008 | 10:12 AM
bahadden's Avatar
im looking 4 something 2 keep all 4 on the ground as much as possible with out completely unloading the springs.
