Help with Springs.
Old Oct 25, 2012 | 04:59 PM
njdan's Avatar
Default Help with Springs.
Ok, here's the deal. I bought a 2" coil spacer kit for front and rear and I also bought new Skyjacker shocks to go with it, but I was thinking of maybe getting new springs and not use the coil spacers. What springs does a 2011 Jk 2 door sport have stock and what should I look for if I replace the OEM ones with? Also would it be better to do new springs with the new shocks or just use the coil spacers?
Thanks.
Old Oct 25, 2012 | 05:17 PM
kbp810's Avatar
Thanks.
Not sure I can really advise you on whats better in regards to spaces vs springs... but to check what springs you have now, take a look at the tag that should be present on each spring; take note of the last two numbers on the tag - that should tell you what springs you have on now. The fronts usually range from 14 to 19, rears from 54 to 60; with the lower the number meaning the softer the spring.
For example, in this picture the last two digits on the tag is 14
Old Oct 25, 2012 | 05:21 PM
njdan's Avatar
Thanks, I will check what I have tomorrow.
Old Oct 27, 2012 | 08:18 AM
njdan's Avatar
ok so I looked at the springs I have, 14 in front and 54 in rear, now if I buy either 18/19 front and 58/59 rear will that make a big difference from what i currently have?
Old Oct 27, 2012 | 09:36 AM
Gman*2007's Avatar
I think you'll probanly gain about 1 1/2 ". I went from 17's to 18's on the front of a 4 door and got almost 1/2"
Old Oct 27, 2012 | 09:54 AM
Freewill's Avatar
Thanks.
If the Skyjacker shocks are the right length for a 2" lift (2" spacers) then they are probably too long to use with stock height springs. There are a ton of 2" to 2.5" lift springs on the market. That's what you most likely need to run with your shocks.
I'm not a fan of a spacer lift when changing springs takes the same amount of work and doesn't cost that much more.
Old Oct 27, 2012 | 12:02 PM
kbp810's Avatar
I made that move with mine and gained about 2" in the front, and closer to maybe 1 3/4" in the rear
Old Oct 27, 2012 | 12:06 PM
rockyjk07's Avatar
I have both the 2 inch spacers and the 18/59 springs on mine lol
Old Oct 27, 2012 | 12:50 PM
Power Hungry's Avatar
Since you've already got the spacers and the shocks, I'd buy some used 18/59 springs to go with the spacers and use the springs and spacers with your new shocks. I just so happen to have some of those springs I'm looking to sell for $100 plus shipping for all 4. :-)
Old Oct 27, 2012 | 01:22 PM
njdan's Avatar
What are you looking to get for them shipped to NJ 08757?
