HELP - Weird Starting Issues
Old Jun 11, 2018 | 11:42 AM
oh_my_josh's Avatar
Default HELP - Weird Starting Issues
Every now and then, my 2012 JKU won’t start unless I bang on the steering wheel a few times. Had the ignition switch checked and that’s not the issue. Has anyone heard of this issue?
Old Jun 11, 2018 | 11:51 AM
REBEL OFF ROAD's Avatar
Former Vendor
Well if banging on it gets it to start up, and you've already had the ignition mechanism checked, it might be a wiring/connector issue somewhere in the steering column. Are you sure its hitting the steering wheel that gets it to start? When the issue occurs, does that solve it every time?
-Kyle @rebeloffroad
Old Jun 11, 2018 | 01:28 PM
oh_my_josh's Avatar
https://www.dropbox.com/s/bmobr7m65l..._4295.MOV?dl=0
Kyle - thank you for your reply. I’ve attached a link with a video of the issue. Hitting the steering fixes it every time.
Old Jun 11, 2018 | 03:27 PM
EHarris's Avatar
JK-Forum Ambassador
Rather than hitting the steering wheel, this time hit the shifter knob and see if it starts. And then if you get a chance, see if putting it into N from park gets it to start. And if you get another chance....lol.....see if it starts when pushing forward on the shifter knob into park.
All I had to do was slightly touch the shifter knob and it would start. I have a suspicion that you are essentially doing the same thing with a hard hit to the wheel.
It could also be a WCM or battery ground or engine ground issue.
