Help-wheels spacers stuck!!!!!!!!!!
anyone have any suggestions to take off wheel spacers. i need to change my rotors but the damn spacers are stuck on.
i took all the nuts off and sprayed alot of wd-40 and hammered them with a rubber mallet but that shit wont come off.
the only other thing i could think of is to heat them up
I am sorry you are having problems, but others need to be aware of this as it has been in the Forum before and one reason I went with different wheels with correct back spacing and avoided spacers .... good luck with your removal, if I remember the last guy to have problems heated them up.
WD/40 is a great product for surface, Try some other products, PB Blaster works great for deeply rusted/stuck items such as this. most automotive shops prefer it over wd/40 as it just has a tenancy to work better. I would spray the hell out of it with pb blaster, let it set an hour, hit it again with some pb blaster then soak for about another 20-30 minutes then go back at it. you possibly might need to use an actual hammer rather then a rubber mallet if the rubber Mallet wont work. yes I understand you risk messing up your spacers. but if you need them off you need them off.
worst comes to worse heat them up. just dont do to much, as stated above you do risk messing them up.
so soak some more with some other than wd then hit some more ill try it out!!!
in terms of heat i seam to be getting mixed responses, how bad would it be to the spacer if i heat just to warm and not to make it
extremely hot
ps please keep the suggestions coming
thx
extremely hot
thx
I mean, why not just keep at it with PB blaster and WD-40, what about lithium grease if you can work it in there? if worse comes to worse, bang em up to get em off and just go with new ones....
If you plan to re-use them and they are aluminum, heat is a bad idea. It takes very little heat to anneal (soften) aluminum. I am sure others will disaggree but if was my rig I would not use heat (or spacers).
I'm on your side.... as I posted the same reasoning above...
Ill post again. Two scenarios:
1) you want to reuse the spacers: In this case PB Blaster the hell out of them and rubber mallet them off. They will come, just need to be patient.
2) you do not want to reuse the spacers: heat them up and pry them off or take a hammer to them and beat them off.
