Help-wheels spacers stuck!!!!!!!!!!
Ill post again. Two scenarios:
1) you want to reuse the spacers: In this case PB Blaster the hell out of them and rubber mallet them off. They will come, just need to be patient.
2) you do not want to reuse the spacers: heat them up and pry them off or take a hammer to them and beat them off.
Originally Posted by SilverBolt
If you plan to re-use them and they are aluminum, heat is a bad idea. It takes very little heat to anneal (soften) aluminum. I am sure others will disaggree but if was my rig I would not use heat (or spacers).
Ok this may sound nuts but at this point you really have nothing to lose, I mountain biked for years and sometimes aluminum seat posts will sieze in steel frames, what I have herd of doing was pour ammonia on them and break it loose, it dose work but you need to keep working in so keep hitting it with a plastic hammer.
I've run Spidertrax spacers on several Jeeps. I know this doesn't help now, but when you put them back on use Anti-Seize on the mating surfaces. I've never had any problem getting them off.
After soaking them with PB, remove the lug nut that hold the spacer to the axle, which I am sure you have, then put the tire back on and the lug nuts that hold the tire to the spacer, then use the weight and leverage of the tire to try and wiggle it off!
Just a thought I had.
I have new rims comming soon(back ordered black MB72's) and hope my Spidertrac's come off easy, might have to try my own advise!
P.S.....Stock 17's in the for sale section soon!
Just a thought I had.I have new rims comming soon(back ordered black MB72's) and hope my Spidertrac's come off easy, might have to try my own advise!
Mine were stuck on there the forst time I took them off. I used a slide hammer attached to the wheel studs, that worked great. I also was able to get them off with the rubber mallet just took more patience but doable.
anyone have any suggestions to take off wheel spacers. i need to change my rotors but the damn spacers are stuck on.
i took all the nuts off and sprayed alot of wd-40 and hammered them with a rubber mallet but that shit wont come off.
the only other thing i could think of is to heat them up
haha
