HELP! Wobble in the front end
Old Oct 25, 2012 | 07:20 PM
deeker's Avatar
There are some good videos on YouTube showing the cause of death wobble.
Old Oct 31, 2012 | 04:08 AM
JK yeti's Avatar
Still have wobble and about every 3 days the death wobble....??
Old Oct 31, 2012 | 02:15 PM
Dbmoorejr's Avatar
Default Death wobble cures
I had a 2003 2500 cummins dodge 4x4. The death wobble started and i replaced a lot of things before putting a set of trackbar bushings in. That fixed it immediately. I haven't had problem on jeep. Also make sure you check torque specs for track bar. Dodge/Chrysler/Jeep will bump them up sometimes without posting it. The 03 2500 was 150 ft/lb and found out when i replaced bushings that A SERVICE UPDATE HAD PUSHED IT TO 200 ft/lb.
Old Nov 1, 2012 | 02:33 AM
JK yeti's Avatar
Alright thanks for the info ill check those torque specs out
Old Nov 1, 2012 | 03:30 AM
danh63's Avatar
I had it on my 05 CTD with 6" lift and 37's. Happened after the truck sat all winter. I did bal joints then steering brace and then got the thurmen fox steering stabilizer and finally that did it
