highway speed driving?
Old Apr 7, 2013 | 07:47 PM
  #21
BlackdogJK's Avatar
The unlimited drive better at higher speeds. I have to fight my 2 door in high winds. That being said, it's a jeep. Keep it at 65. Jeeps are not build for speed.
Old Apr 7, 2013 | 09:33 PM
  #22
gunbo75's Avatar
I put the aev control arm drop brackets and my Jeep drives great now.
Old Apr 8, 2013 | 04:48 AM
  #23
JKphotoshoot's Avatar
I would check your caster first. That will make a big difference if its to much or to little.
In the 2-3 range mine was twitchy. Would change lanes in a second if not paying attention.
I run no stabilizer, 37 mud grapplers and now with proper angles and alignment mine drives great. Even made a Long high speed run in the 90-95mph range and everything still felt smooth as silk. ( except for my shifting like mad auto tranny!)
Old Apr 8, 2013 | 05:54 AM
  #24
mudbug79's Avatar
Originally Posted by Flyingbrian
I don't go over 65 lol
Sent from my i5 using just one thumb and tapatalk
THIS! I just put-put around most of the time.
Old Apr 8, 2013 | 06:00 AM
  #25
demtek9's Avatar
I drive 80-85 (mostly 80) in Colorado like most of the folks on the highway. Suspension setup is key. I had an easy trip back from EJS at 80 the whole way. I installed the KR 2.5 flex kit that included track bar and lower front control arms. My friend has an LJ with 35's too and he did the 2.5 budget boost with no LCA and all he could talk about was his Jeep wandering on the highway and wallowing off road. He's going to get some LCA and springs now.
Old Apr 8, 2013 | 06:27 AM
  #26
navin r's Avatar
As others have said the front suspension settings have to be tight. The effect of the factory front air dam is also underestimated; when I took mine off it made a big difference on the highway especially in cross winds. I replaced it with a RR front skid with a welded on extension that fills the whole front area; after that my JK was mostly back to what it was stock as far as highway stability.
Old Apr 8, 2013 | 06:36 AM
  #27
FLJKU's Avatar
I drive from Orlando to Jacksonville regularly. The first time I did it it was freaky I was blown all over due to the wind (cruising between 70 and 85). The rest of the times with minimal wind it has been fine, for the most part like any other vehicle I've owned.
Old Apr 8, 2013 | 09:35 AM
  #28
Irish Bullfrog's Avatar
A heavy steering stabilizer is a must when increasing tire size and those that don't, are seriously asking for it.. It is not a band aid at all.. Yes, everything must be aligned and tightened properly, but the increase in tire size also increases rolling friction.. The "bump steer" issues are mainly due to steering geometry set up which is why I said a replaced pitman arm ( which most companies list with their kits as required when lift over a certain height), the steering stabilizer upgrade is to help with wheel drift due to a higher contact patch with the ground.. For me, a little under $200 is pretty cheap insurance for my rig and my passengers..
I know I just stirred a hornets nest as some insist that you can be "hardcore" and be cheap too.. I paid 32k for mine and certainly don't mind the "better safe than sorry" phrase.... Ps... A dual steering stabilizer also helps control your flying brick when the wind gets to shoving..
For the record... I drive a '12 Unlimited. 4" Skyjacker Stage 2... 35x 12.50 BFG AT's...
Bullfrog
Old Apr 8, 2013 | 05:54 PM
  #29
White70's Avatar
Thanks for all the advice guys, I drove the jeep again today and everything felt great, brought her up to 80mph and handled really well.
Originally Posted by kjeeper10
The negative to the track bar drop bracket is roll center is not corrected.
For best results--and especially at 3-4" of lift--matching roll centers front/back for best handling.
OP.. You never said your alignment numbers ?
Stock is 4-4.2
toe in 1/16-1/8
Steering stabilizer has nothing to do with wandering rofl
Psi is a big one people over look also.
How do I measure this?
Old Apr 8, 2013 | 06:04 PM
  #30
nthinuf's Avatar
Call around and find an alignment shop that will give a free/cheap alignment check.
Or, go down to the writeups area, stickied on top is an index, find the Basic DIY Alignment writeup. That'll get you a ballpark caster and a decent toe number.
