Hood latch/lock experience/recommendation?
Old Jan 27, 2010 | 07:30 AM
  #31
Mark Doiron's Avatar
Originally Posted by Ynkedad
... I wanted my hook locked for several reasons ...
Ah-hah! Your solution makes perfect sense.
Old Jan 27, 2010 | 01:27 PM
  #32
wmcvey's Avatar
But, I wanted my hook locked for several reasons. The most important was so that I could install an alarm that wouldn't be easily disabled by cutting the power wire. Which would be easy as there's nothing securing the hood other than a few latches.
Forget to ask, I can't tell from your pic. But where is that padlock located ?
Old Jan 27, 2010 | 02:45 PM
  #33
trbn8r's Avatar
G,day Mate
I lost my front plastic dummy skid plate (under the bumper) in a bog. Since then I have noticed that my hood has started to bounce around a lot at high speeds, also my fuel consumption has gone up a tiny bit. See if u can try to divert the air coming from under the Jeep away from the engine bay.
Just my 2c worth
Mani
Old Jan 28, 2010 | 04:15 AM
  #34
Ynkedad's Avatar
Talking
Sorry for the late response..
I attatched the "D"-Link to the square tubular cross bar that's attatched to the frame, that the bumper atatches to, behind where the bumper is. And of course, that's where the padlock goes.
Old Jan 30, 2010 | 04:39 PM
  #35
wmcvey's Avatar
I have a grille mod and couldn't use an after market lock so I did this instead (yesterday)...I'll be brief...
FWIW...
I bought some 1/8th" galvenized cable, and some 3/32" crimping sleeves at Home Depot. I had the Ring and bracket here at the house, but Home Depot sells tie down d-rings. (I have a pic of them if someone needs it).
I put the tape on the ends for several reasons..
1) so I wouldn't get hurt.
2) so the cable wouldn't catch on anything when I ran it thru.
I made the cable short so I could utilize the hood spring in the overall length. The hood pulls tight where as there's no play whatsoever, even w/out it being latched.
Just did this same mod to my Jeep, with two differences. Used 3/16" galvenized cable and didn't use a D-ring of any type. Instead I just wrapped the cable round the framing and pad locked it to itself. Will take a pic. in the morning and post it. Total cost about $5. (had the pad lock). With it installed and the hood OEM latches opened, the hood doesn't open a bit.
Old Jan 31, 2010 | 07:50 AM
  #36
Tiburon's Avatar
FWIW...
I have a grill mod also and installed a Mopar hood lock. Joust a little modification with a dremel and some black rustoleum required.
Old Jan 31, 2010 | 09:44 AM
  #37
wmcvey's Avatar
Looks real good, I thought about doing it this way also. But the price for this lock is so much.
Old Jan 31, 2010 | 09:53 AM
  #38
Tiburon's Avatar
It is expensive. But I have to say it is very stout and solid. It solves the hood dance problem and prevents thieves from cutting your battery cables to disarm your alarm. Also, after installation you program it to work with your ignition key, so no extra key.
Old Jan 31, 2010 | 10:03 AM
  #39
IcyFridge's Avatar
I like the cable tie down on the red Jeep. Where is it locked to? I would like to try this iwth my hood and lock it somewhere under the jeep or something?
Old Jan 31, 2010 | 10:09 AM
  #40
ronjenx's Avatar
MOPAR Hood Lock:
$99 + shipping from wyckoffparts (a sponsor).
