Hood latch/lock experience/recommendation?
Just did this same mod to my Jeep, with two differences. Used 3/16" galvenized cable and didn't use a D-ring of any type.
Instead I just wrapped the cable round the framing and pad locked it to itself. Will take a pic. in the morning and post it.
Total cost about $5. (had the pad lock). With it installed and the hood OEM latches opened, the hood doesn't open a bit.
The hood is held down tight, the OEM latches are just for looks now.
I have the Daystars and they work fine.
I have to vote for the properly installed wire/zip ties. I bought the daystar and they do work but extremely tight even after being installed for over 6 months. I heard the sheet metal crackeling the first time I closed the latches and the lines of the hood and front quarter panels are off. After I read about the zip tie solution I was wondering why I did not think of that one, being an electrician and having the d@mn things in my toolbox.
behind the air dam thing. You will see a framing part about 3" wide, I think it acts as a skid plate. I ran the cable around that,
than just pad locked the loop to the cable. The other poster added a D-ring instead, and locked to that.
My cost was about $5. and maybe 20 mins. of my time, not counting the time to shop at Lowes.
