How bad is it going to be?
Old Nov 23, 2007 | 04:46 AM
stratra's Avatar
Default How bad is it going to be?
I'm going from ProComp x a/t 33's to Toyo m/t 35's. I'm concerned that these tires will really slow me down. I read that they were heavy. I have a 4 door jk jeep with 4.10's. I really want the toyo's now, but don't want to regear just yet(will need more $). Any suggestions on the gears when I do buy them? I feel like the jeep drives well now. I bought the jeep lifted and with 33's, so I have no idea what the stock drive was like.
Old Nov 23, 2007 | 06:31 AM
TEEJ's Avatar
The rpm difference for a 33" diameter vs a 35" diameter tire is roughly 5-6%....with the larger diameter dropping the rpms and a smaller diameter raising the rpms to maintain a given speed, etc.
Example -
For whatever speed you're at, if you stay at the same speed, but with the 35" instead of the 33" tire, with the following rpm on your tach:
At 3,000 rpm on your tachometer, the 35 would drop the rpm from 3,000 to around 2,820 - 2,850-ish.
At 2,000 RPM, it would drop you to about 1,890-ish, etc.
Hope that helps.
Old Nov 23, 2007 | 07:33 AM
stratra's Avatar
Default Auto
I have an auto. Here's a picture.
Old Nov 23, 2007 | 08:01 AM
scootrrydr's Avatar
Ur jeep looks good with those half doors......
Old Nov 23, 2007 | 08:02 AM
DeepSky's Avatar
You'll probably notice a difference, but it won't be unbearable.
I have a 4 door Auto on 35"s with the 4.10s and so long as the overdrive is off its pretty quick.
Old Nov 23, 2007 | 09:07 AM
Ctimrun's Avatar
You will notice a difference, but it won't be huge or unbearable. I've got the same, auto, 4.10's, 35 " Toyo's. Those tires will look badass on your Jeep! Do it.
Old Nov 23, 2007 | 02:44 PM
Piginajeep's Avatar
Damn, I love the wheel and Color choice!
Old Nov 23, 2007 | 02:46 PM
mkjeep's Avatar
I have 35in Cooper STT's about the same as the Toyo's. Also have 4.10's, like Deep sky said , press the OD button off and you'll be good.
Old Nov 24, 2007 | 09:35 AM
mkjeep's Avatar
Old Nov 24, 2007 | 09:38 AM
RedRockJK's Avatar
35's, 4.10's, and an auto aren't too much fun on the highway if you come to any kind of inclines. The tranny likes to kick down into 3rd quite a bit in that case. If you don't mind that you will be fine.
