How hard is it to install a cb?
Old Aug 19, 2011 | 05:50 PM
Jeremy072288's Avatar
Default How hard is it to install a cb?
Im not real good with electrical work so can anyone walk me through it? I'm hooking it up tomorrow thanks
Old Aug 19, 2011 | 06:05 PM
gludo's Avatar
Default When the will is strong, everything is easy!
It is not that hard. Have you tried doing a search for "CB install"? I would do an advanced search for title only. I used a fuse tap to power mine. You will also need to use an SWR meter to tune your antenna, if you want to get the best performance out of it.
Old Aug 19, 2011 | 06:15 PM
nthinuf's Avatar
Hit your backspace key, then scroll down a few sub-forums to the CB & Ham Radios area.
The install is pretty straight forward. The issue you may have is finding someone with a SWR meter to tune it.
Old Aug 19, 2011 | 06:36 PM
AMen's Avatar
Here is a write up from Project JK
This is the one I did and it was easy
http://project-jk.com/jeep-jk-write-...nd-model-1001z
Later
AMen
Old Aug 19, 2011 | 06:51 PM
dogsonparade's Avatar
It's as difficult or in depth as you want to make it.
I'm stuck on SWR tuning - time to read.
Old Aug 19, 2011 | 07:08 PM
xerofall's Avatar
The hardest part for me was grounding the antenna properly. Once I got that down, all the rest was child's play.
Old Aug 19, 2011 | 07:15 PM
jkdan09's Avatar
Its a piece of cake, just make sure you have a good ground..
Old Aug 20, 2011 | 12:00 AM
TANGOJKU's Avatar
why grounding the tailgate to the tub with a wire? (orange in this case)
if you don't do this what's may occur?
Old Aug 20, 2011 | 03:36 AM
OH9JK's Avatar
JK-Forum Ambassador
This would be done only if you have a CB antenna mount on your tailgate. The reason is the hinges do not allow for a good constant ground between the tub and tailgate. You will get very inconsistent SWR readings which leads to poor performance and possibly damage to the CB radio. You must remember that the whip is only 1/2 of the antenna system....your Jeep makes up the other 1/2. Ground, ground, ground!!
Old Aug 20, 2011 | 03:41 AM
Anyone here have a firestik antenna and cable mounted on a TF spare tire mount? How did you set up/ground?
