How much capacity
Old Jul 31, 2009 | 09:47 PM
hammontroy's Avatar
Question How much capacity
I need to come up with a stop gap way to pull myself out until I get approval from my wife to by winch. After doing a search, I came across a thread in the 101 section talking about using a hi-lift as a manual winch. One of the responses, however, talked about how much work it was and recommended using a come-along, specifically a Wyeth-Scott puller. This got me thinking about winch capacity. From what I’ve seen it looks like most 4-drs are going with 10k or so but the beefiest puller this company sells is 6k. So how much pulling capacity does one really need for a 4dr? On a rock? In the snow? Etc?
Old Jul 31, 2009 | 11:45 PM
Clownhunter69's Avatar
Vet: Army
I have pulled myself (4 Door), and about 6 feet of mud in front of me, for about twenty feet with my cheap-o Smittybilt XRC8. I was planning on using it just until I could affford a Warn, but have since changed my mind. This this has come thru for me everytime. This thing saves a lot of $$$ over the other companies, and if you think you'll need pull, buy a pully block and you'll effectively double the line pull.
I have also used a High-Lift to pull my old CJ5 out. I agree that it takes forever, a lot of effort, and you only get to move about 4 feet at a time. And trust me, you'll want to stop after about two. Another problem is that you'll need something to hold the Jeep while you reposition the high lift after each 4 foot pull. Nothing worse than sinking back into what you just pulled yourself out of.
If you must go with a manual pull, go with the Come-a-Long. 6000 lbs should be enough for a rolling pull. Save the high lift for emergencies and jacking duties.
Old Aug 1, 2009 | 06:43 AM
hammontroy's Avatar
Do you think it needs to be the 6k version that is pretty spendy by comparison or would an 8k $30 come along from Harbor Freight work, say in a snow bank?
Old Aug 1, 2009 | 07:15 AM
wayoflife's Avatar
JK-Forum Founder
for minor pulls, a come along will in fact work just fine. the more capacity the better. if your jeep is really stuck and in a bad way, you really should use a winch with a minimum 8,000 capacity. add in a snatch block and you can do some real pullin.
Old Aug 1, 2009 | 07:33 AM
jkkat's Avatar
A stuck 4Dr weighing in @ 6000 Lbs can use closer to 12,000 Lbs of force to get it out of that spot, and i mean all four wheels in the air and dragging frame stuck.
Old Aug 1, 2009 | 07:44 AM
hammontroy's Avatar
I agree but right now I'm thinking more about sliding off the road in the snow. I would love a winch and even have the bumper for it already, but so far, I have not been persuasive enough.
