How much of a Difference do Front Lower Control Arms Make?
Night and day improvement. I have a 2" OME coil lift (about 3.5" of lift) and my caster was at 2.3 after the lift. The ride was sloppy and jumped around when hitting a bump in the road. I also had issues with the ESP coming on on banked turns. I added the TF adjustable lower control arms and set the caster to 6 and no more ESP issues and the handliong is now much better than stock. The whole front end now feels tight.
Sounds like this is a good option for me then. As far as the caster setting, around 6 seems to be the recommendation. Is that correct? Also do I only need the FLCA's to get these results? Thanks for the suggestions.
What is the recommended diffrence between the front right and left caster? If the front left is 5 and the front right is 4 is that ok or is 1 degree to much?
On my 4 door, I have 1/2 degree difference between right and left to account for the road crown on PA country roads. Seems low and I am going to adjust to a 1 degree difference shortly. I am still pulling right on crowned roads.
