how much tire can a d30 take?
The difference in diameter from 3.73's to 5.13's is about 72%, meaning that if the diameter of the stock pinion is 2", the diameter of the 5.13 pinion is 1.45". (just random numbers... I don't know the exact diameter) That is one point of common confusion in the JK world... while we are the first to jump on tall gears to compensate for our "minivan engine", we often forget that we build in a little bit of weakness by doing so.
That said, the quality of manufacturing for aftermarket gears seems to be better than stock anyway. (the only failures I personally have seen came from stock gears) If we even get a 25% strength improvement from better metals, it might well offset the difference in size. And... because our engines are known to be weaker, there is less chance of grenading the R&P.
This is a long winded way of saying... R&P are the biggest weakness in a D30 and there are not a lot of good ways to offset that. Axle shafts and u-joints are another weakness, but they are easy to replace and a relatively inexpensive fix. And of course... the whole problem with the tube and C's, but that is not a problem specific to the D30's and should be fixed if you plan on wheeling hard with a mopar 44 as well.
Not true, the D44 u-joints are a series larger than the D30.
http://project-jk.com/wp-gallery2.php?g2_itemId=79190
I was really frightened when I saw how small the pinion was on my 5.13 for my D30. It made me wonder if 4.88s would have been smarter. But I spend 99% of my time on the road, and offroad I am very conservitive on the stupid pedal so I am happy with my choice. That said, I am thinking about going D44 over building my D30 like I had planned. We will see I guess.
MOWrangler,
I really like you're rant here and how you laid it all out. I still think that I want to beef up my D30 with gussets and a truss, but I'm thinking that I don't wanna waste money on a front locker with it. You've made me wanna search a little harder for a front rubi 44 swap to have on standby. I never really thought about how much the regear changes your R&P strength and because of all of this my plans have really changed.
I'm gonna stick with the D30 for now just to see how much abuse it can take, but now instead of regearing and spending all this money trying to get more out of it, I'm gonna be looking into swapping it out.
I don't know if anyone else is getting anything out of this thread, but I'm getting some good info. Thanks to all the posters
Seriously, if you are just running it up and down the road you will never generate enough torque with the 3.8 to be concerned. I was more or less afraid that when I was out on the trail in 4Lo with 36" TSL's, that would push it over the edge. It is really a fine line to walk, and I already have a bad habit of using too much skinny pedal.
I will admit that building the 30 is probably going to be a 12 month solution for me. I just couldn't come up with the cash for a 60 right now, but I knew I needed to step up to the plate to be able to keep up with the big boys. Running the 36's with 3.73 is just miserable, and I expected to replace my street tires before the end of the year as well. So... the stars just lined up to build as much as I could afford.
I also know guys who have wheeled XJ's with a HP30/44 combo for a long time without problems, so maybe I am just over cautions. Of course, I saw G.I.JOE¤MFA¤'s 39.5" Pitt Bulls today and have to admit that all of a sudden my 36" tires seemed a little inferior.
