How safe are SOLID diff covers
Solids are not garbage. They get beat hard here on desert rocks several times a week and not a drip one. My only issue is the bolts get flattend but the cover is still good as new. Several of my desert rat buddies run them and no complaints.
The grinding deal is just to accomodate the Rubicon's switch that is not an issue on other D44's and just takes matter of minutes.
sorry for sounding mean here but...........
If you can't grind off a little excess metal, see why you are doing it, and understand this does nothing to undermine the structural integrity you should not be working on your jeep past installing a bobble headed doll and/or chrome pieces.
step away from the jeep, step away from the jeep.
The grinding is a simple way to make thesolid d44 covers accommodate the JK, sincethe covers were designed before the jk came out. Really it is a heavy, thick piece of metal, and grinding off alil bit is a reasonable way to make them fit the jk Rubi. I've smashed mine into rocks lots of times, with no issues. If you don't want to grind, really, go pay twice as much for the ARBs or some other cover.
your ignorance does nothing for this thread. The covers have been around for years and have been used and beat on comp rigs that you could only dream of putting your JK through.
The jk d44 is the same as the previous models, if you want them to Jack the prices if the covers up, I'm sure they would spend the money and have new casts made for the JK. Must jeepers love the chance at grinding on something
Once they sell out of the remaining SOLID D44 covers then they plan to cast the new covers with the new company name which will not have to be grinded to accomodate oem lockers.
Of course they will go back to normal price when the new ones are available.
We've beat up on a set for over a year with no issues...
Not to mention the covers also come with the below instructions in the box.
http://www.solidaxle.com/PDF/44_Rubicon_Fitment.pdf
http://www.solidaxle.com/ProductCart/pc/viewPrd.asp?idproduct=33&idcategory=7#details
60 seconds of grinding to save $60 seems like a non brainer decision
Last edited by HappyCurmudgeon; Feb 2, 2010 at 08:37 AM. Reason: removed hyperlinks
Rubicons come stock with factory lockers, but factory lockers can be options on other models like mine.
They should be selling 2 models -
A) one for no lockers/old style
and
B) one that works with or without lockers/new style...
...until they run out of model A's. then only sell model B's, not make customers grind it after purchasing! plus - what happens if you miss this pdf, you/the customer damage your locker???
IMO - that's just lazy and poor customer service!
and
