How safe are wheel spacers???
Has everyone been able to get the vehicle inspected with no problems with spacers on? They wouldn't do it here
so I put them out of my mind. Already have a short list of other things I need to undo before I bring it in so was not looking to add to the list.
i didn't want to use my stock wheels and went to aftermarket.
I wish i would have gotten a stock set of moab's and spacers because the finish on my after market's has gone to shit even with maintainence due to our road salt in the winter..
Keep it simple and just add the spacers unless you don't live where it snows.
I have been using my spidertrax spacers for the past 33,000 miles with no issues. When I installed them I went by the directions supplied and used the lock-tite they provided and torqued to 90ft/lb.
Each time I rotate my tires I check the torque by setting my wrench to 85ft/lb (so that I don't break the locktite), and make sure all lugs are still secure. So far none of them have loosened up over time.
I would say that they are safe as long as you are smart about using and maintaining them.
Originally Posted by Freak
Do not back the lug nut stub back out. Just put a torque wench on it and make sure its torqued to spec. You should be using red loctite, also.
Got it, but Isn't red loctite very hard to remove? I thought blue so you can still remove it later on? I got my spidertrax spacers used so I didnt have the loctite that spidertrax provides. So I used blue loctite, torqued to 90lbs, then retorqued after 50 miles as per the directions from spidertrax. 2k miles on em so far and no problems. Just want to make sure when it comes time to rotate my tires I retorque them the right way
The sandwich style spacers can be very dangerous, but are not so in their own right. If you have a 6" long wheel stud and stick a 3/4" sandwich spacer (shown above) on there then you'll be fine.
Have you any personal experience with these style of spacers? I do. I use them daily on my Corvette with no issues. Ready for the shocker? MANY people use these little sandwich spacers on older Corvette's to fit newer wheels on the front. Now that is important, hold on to it for a minute. "Front" is important because in the rear we do something different, the bolt-on style of spacer.
Can sandwich spacers be used in 1% of applications? Maybe, but for the vast majority of applications that are asking for trouble.
