How safe are wheel spacers???
Old Jul 30, 2011 | 12:32 PM
  #21
JKSLEEPR's Avatar
I've got over 25,000 km on my Spidertrax 1.5" spacers - followed all the install instructions, check them when I do a rotation. No issues, no problems.
Old Jul 30, 2011 | 12:47 PM
  #22
knight1000's Avatar
Originally Posted by Runewolf1973
I have a question about that.... I am going to assume you put the Red locktite on the threads when you initially install the spacers, but that stuff has a cure time after which it is supposed to dry really hard. How are you supposed to retorque the bolts when they have cured Locktite on them? Even if you were able to torque the bolts more, the Locktite has it's own specific breakaway torque rating, so wouldn't that extra torque after 100kms just break the bond of the Locktite anyways, defeating the purpose? Maybe this is just a dumb question, but just trying to understand how this would work. It just seems to me that the Locktite is designed for something that requires a permanent bond with no further movement, rather than something that needs to be retorqued.
I was wondering this also. So if you find one to be loose and need retorque, should you reapply Locktite?
Old Jul 30, 2011 | 12:58 PM
  #23
Runewolf1973's Avatar
I would assume you can't just reapply it unless you take the nut off completely and clean the threads of all the old stuff, then re-apply it...but then you'ld have to retorque that nut after so many km's anyways, thereby breaking the Locktite bond yet again. My guess is that if you apply Locktite initially, it should prevent any loosening to begin with, so any retorque (theoretically) should be unnecessary and may even be counter-productive to the product's intended purpose. Maybe I'm just over-thinking this....sorry.
Maybe the Locktite company/manufacturer would have some advice about this?
Old Jul 30, 2011 | 01:53 PM
  #24
untold's Avatar
The locktite is there to take it from loosening its self. Your going to check the nuts every so many miles just to make sure they still torqued. (not breaking them loose and retorque them down) When i check my spacer and i set the whench at 85 and if it clicks every thing is good and then i move on. The red locktite is some strenght stuff and shouldnt be taken lightly. I havent heard of anyone that installed the spacer the right way, ever heard of anyone having a nuts loose during one of they "checks".
Old Jul 30, 2011 | 09:19 PM
  #25
bkjeep's Avatar
Been riding 1.5 spidertrax for 70,000 miles 0 issues. Look great, love them!
Old Jul 31, 2011 | 07:22 AM
  #26
porters's Avatar
Originally Posted by Langhorne
Has everyone been able to get the vehicle inspected with no problems with spacers on? They wouldn't do it here so I put them out of my mind. Already have a short list of other things I need to undo before I bring it in so was not looking to add to the list.
No problem for me. They complained about the rear brake pads and did not mention the spacers at all. Also, I have 40K on mine with no problems.
