How to tell which 15" alloy wheels will fit my '12???
Got a lead on some 15" alloys that my brother-in-law is giving me. They are Desert Rattler Tracker II from Desert Rat. They are a 15x10. How can I tell if they will fit my '12 before I get them from him? If they won't fit my rig, I'm going to tell him to sell them locally (he's in CA and I'm in MS). I emailed Desert Rat and they said they recommend 17" wheels for the '12 wrangler. How can I be sure these will or will not fit? Are there some measurements I can get to see?
Thanks,
Kevin
Thanks,
Kevin
JK-Forum Founder
most alloy wheels will NOT fit on a JK or, a least, not without doing some grinding on your brake calipers and even with that, it's too tight for my taste. i would pass on them but, that's just me.
I have 15" alloys and they fit with no issue. They are 15x8 with 3.75" back spacing. For a 15x10, you will want even less to avoid rubbing
Look at the back of the wheels you have and the backspacing should be stamped on the hub. It also doesnt hurt to do a test fit with no tires
edit: just checked desert rats website. Says they are 3.75" back spacing. They should fit but it will be close with the wheel weights
Thanks,
Kevin
Discount tires write up
Heres a link to a thread started by Discount tires, one of the sponsoring vendors here. I am running this set up my self on my 08 JK and I love it. Love the look and continuously get complimented on it. Im sure they will answer any questions you may have good luck
http://www.jk-forum.com/sponsoring-m...-steel-120933/
Thanks,
Kevin
