How's my list look?
Old Apr 25, 2011 | 01:53 PM
Rancho's Avatar
Sponsoring Manufacturer
Shocks?
Didn't see that on the list.
Old Apr 25, 2011 | 02:20 PM
ncaa_maniac's Avatar
Originally Posted by jeep2007
List looks fine as is. BUT, if it were me, since your at 3" of lift, I would skip the arms and save that money and invest it in gears. Arms will be a great upgrade, but not needed with this yet. Full Traction makes great stuff. You will want trac bars front and rear.
Yeah but the arms are only $350, combine that with BD and its $700, but gears are aroung $1200. Do I need a rear trac bar for sure? I thought a bracket was enough since that is what almost all the lift kits include.
I don't know about the rear pinion angle. I know the 2 doors have a bigger issue with the rear driveshaft. Just ask around a bit more on that one. You may save some money not getting rear uca. (obviously the more ca the better).
The evap thing is just cheap insurance. Relocating is probably best. I wimped out and did the skid. I'm on my second one now. The first saved my rear driveshaft, but then started rubbing on it at full flex.
Yeah I think I would relocate because eventually I want to move the muffler where the evap is now.
dont bother getting the bully dog and put that money to something usefull like lockers. a rear lunchbox locker would make a huge difference.
Well, like I said I will only be doing some crawling not a lot and I need the BD to get back some HP and MPGs and also to correct the computer.
Shocks?
Yep I have Bilstein 5100s on there. I know that's not your favorite kind though
Old Apr 25, 2011 | 03:05 PM
Rancho's Avatar
LOL Didn't even see them.
Old Apr 25, 2011 | 03:35 PM
will16's Avatar
I did similar to you... Running 35's with a d30 but I did a little more axle mods... Inner sleeves and chromoly shafts. I also did the gears... 4.88's with a manual tranny. IMO the one thing you are really going to miss are the gears. I know it is more money but I think definitely worth it.
Old Apr 25, 2011 | 03:39 PM
PainKiller's Avatar
looks good might need to grab some rear coil correction spring wedges, evap skid ...my
Old Apr 25, 2011 | 05:02 PM
Yeah sleeves are definitely on my radar but I think I will stick with my stock shafts because I would rather them break than the gears. I think I am going to get lift and tires first then see if I can live with the stock gears, if not I will forget the or-fab and 5th wheel and tire and get new gears.
Hmm... I didn't think about the wedges. I will probably wait until everything is installed and make sure I would actually need them.
Old Apr 26, 2011 | 12:47 AM
MDJKER's Avatar
I recently went through the same dilemma when purchasing my mods. I wasn't able to stay under $5K. However, I kept total cost down closer to my budget by holding off on rear UCAs and a tire carrier in favor of larger (numerically) gears. Good luck, you'll have a damn nice rig when it's all done.
Old Apr 26, 2011 | 05:47 AM
NorthGAX's Avatar
I am looking at going with a 3" lift and 35" and price wise I am almost $1K less than you.
Here are my thoughts:
Ditch the new wheels and run spacers on your current wheels. (Save ~$600)
AEV Pro-Cal to correct the computer. (Save ~$200)
Unless you want the OR-FAB carrier you could go with with the Bestop (HighRock 4x4) tire carrier. (Save ~$250)
So by my executive math that could reduce the cost by $1050.
If you are going to be on the road 95% of the time why go with a M/T? You might be able to lower that price by going with an A/T.
Old Apr 26, 2011 | 05:53 AM
08RedRecon's Avatar
If it is a 95% DD, why: Nitto Trail Grapler M/T x5 1528.75
I would look at other tires
Old Apr 26, 2011 | 05:56 AM
dlincoln91's Avatar
i would not recommend the rough country arms. the bushing seemed to be very cheap and i went through 3 sets of them in 2 months. spend your money right on that stuff.
