hydralic winch vs electrical winch
I am considering about getting a winch now.
Seems most people are using electrical winch, but I personally hesitate to
buy one because it suck battery out quick. I currently prefer hydralic winch
since it seems lighter, more durable and most importantly, does not suck
too much from battery.
The only drawbacks I can find are:
1. your engine must run when you use hydralic winch. But I seem most jeepers
run the engine while using electric winch. So I guess it is OK
2. it requires fluid from power steering, so I guess the wiring work will be
more than electrical one
Any thoughts, suggestion, correction, suggestion?
I won't run a PTO due to the lines necessary to run it, and the engine has to be running to use it. I just don't care to deal with that myself. I'm not even sure the stock power steering pump kicks out enough to handle a PTO winch?
