Hydro assist cooler with Ripp
Old Jun 1, 2015 | 11:09 AM
Justinn407's Avatar
Default Hydro assist cooler with Ripp
I know this has prob been covered but I have been searching for days with no luck. My stock steering pump crapped out on me and now waiting on my new psc pump/res to arrive. While I have everything apart I would like to install a cooler but most of what I see from others have it mounted in the grill area which is not an option for me since my ripp inter cooler takes up the majority of that area. Someone with a similar setup please help. I've seen someone mount the cooler between the radiator fan and the engine but I'm concerned about the heat in that area and would like to find other options. What type of cooler and mounting location??
Old Jun 1, 2015 | 11:36 AM
TOTL Innovations's Avatar
Former Vendor
I dont have a ripp but I do run a Howe hyrdo assist set up with one of their in line coolers:
In-Line Coolers | Parts Categories | Howe
Might be easier for you to mount one of these...
Old Jun 1, 2015 | 11:40 AM
Maertz's Avatar
Mines under my front bumper for now. I want a radiator style with fan though. The inline one just does not cut it on mine.
Old Jun 1, 2015 | 12:09 PM
D_engel's Avatar
I mounted mine on the front crossmember between the rad and engine. The fan keeps air moving over it which has been sufficient for me even in hot az wheeling. My ps reservoir would bubble over completely stock, but hasn't given me any issues with this setup.
Old Jun 1, 2015 | 03:38 PM
Justinn407's Avatar
Do you have any pics of this location and the type of cooler your using?....
Old Jun 1, 2015 | 05:33 PM
D_engel's Avatar
Its a heatsink style dual pass. 14" if i recall correctly.
Simple bracket with U bolts
from below
looking from above
Old Jun 2, 2015 | 12:20 PM
Justinn407's Avatar
Thank you so much for the pics, I think I will go this route and just ordered my cooler as well. One last ?... Do u tap in between steering box and res... Or res and pump?
Old Jun 2, 2015 | 05:03 PM
D_engel's Avatar
the return from steering box to res. Its the hose on the side of the res, If I recall correctly.
