Hydro or Nitro Shocks??
what is the biggest gain in using a nitro shock? is the difference very noticable? performance wise?? just curious to see if its worth shelling out the couple extra bucks
The biggest difference in a nitro charged shock is that it will resist shock fade. After prolonged shock cycling, the oil in the shock will begin to cavitate (froth and foam up). The effect is similar to having air in your brakes. The shock piston has less and less resistance due to the bubbles in the oil.
A nitro charged shock places the oil under pressure which will minimize cavitation.
Hope that helps!
Hope that helps!
