i got 40s!!
Old Feb 26, 2013 | 09:28 AM
beaker44's Avatar
Originally Posted by Jeek.OlllllllO
Do you have a d30 or 44 ?
I know the front axle is a 30 im not sure about the rear axle
Old Feb 26, 2013 | 09:30 AM
Jeek.OlllllllO's Avatar
What year because some 07's came with a 35 in the back but other than that they all have 44's
Old Feb 26, 2013 | 09:33 AM
beaker44's Avatar
WOOOWW!! a lot of problems come with 40s then...i was actually thinking of getting 37s but the 40s were at such a good price i couldnt pass on that deal haha
Old Feb 26, 2013 | 09:34 AM
beaker44's Avatar
Its a 2012 4 door
Old Feb 26, 2013 | 09:36 AM
CoreyZ's Avatar
Uh.. no they dont. Rubi's were the only ones that came stock with 44's.
Christarp's Avatar
Yikes, definitely save up to get new axles (front and rear if you can, but front first most definitely).
You could probably street it for a while on a D30 with 40s but... Yeah thats a huge tire for a dana 30
Old Feb 26, 2013 | 09:39 AM
Christarp's Avatar
He means in the back.
SOME 07 non-rubicons had dana 35's in the rear (at least that's what i've heard), and apparently the dana 44 was an option with the 07 non rubicons (as was 4.10 gears)
all 08-present have dana 44's in the back from the factory.
all 07-present rubicons have dana 44's in the rear from the factory
all 07-present non-rubicons have dana 30s in the front from the factory.
Old Feb 26, 2013 | 09:49 AM
Yes! I have a 07 with a 44 in the back with 4:10.
And a d30 up front!
And my buddy has a 35 in the back
Old Feb 26, 2013 | 09:50 AM
I was talking about the back sorry should have been more clear about it
Old Feb 26, 2013 | 10:23 AM
hypeiv's Avatar
I would get c-gussets welded on asap and maybe think about getting a truss
Artec Industries JK Front Axle Truss
If you are going to regear it might be worth getting the axles sleeved, but in general I don't think they sleeving a d30 is worth the cost.
The C's and truss will help your axle warping issue but your next problem will be with 4.88 or numerically-higher gears your ring and pinion for the d30 will get pretty small (weak) so you will need to take it easy if you wheel it.
If it was me I would get c-gussets, truss welded on b/c its pretty cheap, but start saving for a new front axle if you plan to wheel it hard.
