I need Help
Old Aug 25, 2009 | 04:33 AM
thejeepjunkie's Avatar
Default I need Help
I bout a 4in rough country suspension lift a while back from ebay for my two door wrangler well im looking into it and i find out its a 4 door kit and i dont think they will swap out the coil springs with me and thats the only diffenience between the 4door and 2 door kits. does anyone know what i can do?
pm Me Please or post up to u
thanks
Old Aug 25, 2009 | 04:37 AM
Default I need Help
thanks
Old Aug 25, 2009 | 04:46 AM
racer83l's Avatar
use it. itll give you a bit more than 4"..
At least, thats what I would do.. I mean your going 4" which means you need new shafts anyways
Old Aug 25, 2009 | 04:47 AM
racer83l's Avatar
damn i feel like I just read this thread form the "extreme tech" section
Old Aug 25, 2009 | 04:49 AM
what do you mean? will the 4 door springs fit? i went here http://www.roughcountry.com/jeep_jk_4.html
and it just says theres custom springs for both of them im goning to give them a call in a bit but i just got the rims and tires and wanted to put it on today
Old Aug 25, 2009 | 05:08 AM
RDY4RKS's Avatar
Generally the springs are stiffer for a four door as it has more weight. They 4 door springs should work on the 2 door. It will just sit a bit higher than 4".
Old Aug 26, 2009 | 10:50 AM
yea but wont that mess up things and or make the ride horrible?
Old Aug 26, 2009 | 11:45 AM
jasonclarkusaf's Avatar
If your doing a 4"+ lift on a two door without new drive shafts, there are things you will probably want to worry about more than ride quality. Is your JK an auto or manual?
