I REALLY need some help !
Old Aug 3, 2009 | 07:35 PM
cyruspura's Avatar
Originally Posted by JKDoc
You break your Dana 30 with your right foot, not with 35 inch tires. That said, the gussets do strengthen the Cs and will help keep your tires aligned properly. I elected to upgrade to an alloy axle shaft while everything was torn apart but the right foot can break that one, also.
Just remember, "Slow as I can, fast as I must." If you are not spinning the tires, it is highly unlikely that you are going to break your axle.
I have the six speed and went to 4.56 gears. The pinion is smaller in the Dana 30 then the 44 and going to a higher numerical ratio than 4.56 gets the pinion very small in the 30. The pinion becomes the weak link instead of the axle knuckle.
I would actually advise against getting chromoly axle shafts, especially if you are installing lower gears in that front Dana 30. By reinforcing the shafts, you are making the already small gears the weak link in the chain. I'd much rather break a u-joint or shaft than break the ring and pinion on the trail.
Old Aug 4, 2009 | 12:05 AM
mkjeep's Avatar
I've wheeled mine on average once a month for 2yrs on 35's , d-30 still kickin.
Old Aug 4, 2009 | 05:08 AM
slacktide's Avatar
I agree 4.56 to 4.88 and that said the 4.56 is your best bet on the d30
Old Aug 4, 2009 | 05:29 AM
lv jk's Avatar
***erator
I have 35's, 3.73, auto and the 4 door. It wont win a race but I love it. Will regear someday $$$.
Old Aug 4, 2009 | 06:49 AM
aBē's Avatar
I still don't know what to do... I don't want to take the wrong way
Old Aug 4, 2009 | 07:17 AM
CTNEDGE's Avatar
I also have a 4 door with 35's and a D30. Just returned from Moab and the only thing I tore up was that pu**y excuse for a front driveline I was given by Chrysler. That was probably too much flex however. Get your 35's, get your gears and take it easy on the gas. You'll be fine..
