I want more guages.
I am thinking of installing an electrical voltage and oil pressure guages. I want to even it out with three. What other guage would be most helpful for wheeling? I saw a diff temp guage, but not sure how to go about hooking that up.
Does anyone know if the temp guage in our console for water or oil?
If you want to be able to monitor a lot of items, you might consider the Aeroforce Interceptor scan guage. It hooks up to your OBD2 port and monitors all the JKs sensors and provides a lot of information at a glance, including engine temp, transmission temp, battery voltage, brake pressure, torque coverter lock up, etc.. You can also add sensors for engine oil and pressure on the same guage (analog). It has built in alarm to monitor parameters that fall out their operating range. Pretty cool for just one guage. Comes in many LED and facelpate colors. The model for Jeep JK is CNCx01
htt p://ww w.aeroforcetech.com/Chryslertech.html
If you want an easy way to install engine oil temp and pressure sensors, use one of these sandwich adapters on the oil filter.
