I want to order this setup, will it work?
Old Mar 18, 2008 | 06:18 PM
gongetya's Avatar
Default I want to order this setup, will it work?
I really want this setup for my 2008 2 door x. I have a 4" superlift with no other mods....is this a possibilty for me without any other mods?
Pro Comp Xtreme Alloy Series 7189
16x10, 5 on 5 Bolt PatternBackspace 4.5 in.Hub Centric No, Offset -25mm
along with these tires:Super Swamper TSL/Thornbird Tire
TSL/Thornbird, 35/12.50-16LT Overall Diameter 34
Old Mar 18, 2008 | 06:23 PM
broom's Avatar
I bet it will work fine. With the backspacing, you may have minor rubbing when you turn very sharp. Also, most people use 8 inch wide wheels with 12.5 inch wide tires for off road purpose. (more rubber sticking out protects the rims)
Old Mar 18, 2008 | 06:55 PM
gongetya's Avatar
Thanks for your response..this is my daily driver, so maybe I wont experience the rubbing so much..do you know how to fix that? Is the solution some type of spacing, or would I have to shave my bumper or something?
Old Mar 18, 2008 | 06:56 PM
04DrBlur's Avatar
if you plan on strictly staying ON road. If you off road with those tires you will get stuck.
Old Mar 18, 2008 | 07:02 PM
gongetya's Avatar
Why do you say that? Lack of power? or the rubbing issue?
Old Mar 20, 2008 | 04:46 AM
screws's Avatar
Its because those tires SUCK in the mud, dirt, wet roads, well just about all around they suck. I had a set of 36's on a dodge a few years ago and hated them!!!
Old Mar 20, 2008 | 04:50 AM
element981's Avatar
Back when I was in NC and had my lifted Bronco I wheeled with a guy who had those and we called them Thornturds. They suck bad! He was locked and I was not and I got throw stuff with ease and at times he could not; even fully locked.
Old Mar 20, 2008 | 06:03 AM
brianb1222's Avatar
A Guy In My Club Has A Cj Locked And A V-8 And Is Stuck Every Time We Go Out.
Old Mar 20, 2008 | 06:34 AM
armycop's Avatar
Attachment 7178
Attachment 7179
I think some members have had some driveshaft issues with a 2-door and that much lift. I think Piginajeep had problems because of the angles. Do some research before you go with a 4" to see the best options. I agree with the Thornbird reviews, pretty bad for a DD and not that great on the mud. Better to go with a high quality M/T tire like BFG, Nitto or Toyo, etc.
Old Mar 20, 2008 | 08:06 AM
gongetya's Avatar
Thanks for your help folks. Much appreciated
