ideas on interior door lock security without any top on.
Carrying the Yeti with the top down and doors off is tricky. I certainly don't advertise it! I use a master lock cable and run it through as many loops on the cooler as I can and secure it to the Jeeps tire down rings. Not impenetrable but someone would have to basically ruin the cooler to steal it. I put it under the folded soft top and cover it with a towel. After that it's🤞🏻. If the tailgate is locked then the contents of the cubby are pretty secure. Last thing I installed was a tufty security glove box where I can put semi valuable items. I don't keep anything of value in the plastic center console. I feel one good tug and you're in.
You realize that the jeep has a built in "kill switch" of sorts, right? Someone can copy your key but without programming it (2 working keys or full on dealership codes) it'll start, run for half of a second, then shut off. SKIM is what it's called, look it up if that interests you. It works pretty well, I cut my own key and started the jeep without programming it, just to have it shut right back off. Programmed it and it works as my keys normally do.
