ideas for mounting mag lite
Old Sep 1, 2010 | 07:34 PM
spleify's Avatar
Originally Posted by rubi08unlimited
I went to home depot and they didn't have anything along these lines. Who manufacturs those clips and are they made specifically for the mag lite?
Here you go
amazon.com/MAGLITE-ASXD026-Flashlight-Mounting-Bracket/dp/B00002N9ER[/url]
Old Sep 1, 2010 | 07:35 PM
spleify's Avatar
Originally Posted by Mark in Va
Put mine on the drivers side seat bracket as well. Ace Hardware had the MagLite brackets for around $10.00. Very handy location but you can't get to it without opening the door. Usually only need it when you get out anyway.
I can get mine out with the door shut, if it is to tight try pulling it forward and sliding it out the front of the brackets
Old Sep 1, 2010 | 08:20 PM
rubi08unlimited's Avatar
definitely gonna pick up some of those brackets. Anyone else that's mounted a flashlight elsewhere?
Old Sep 2, 2010 | 03:58 PM
I was thinking of mounting it to the glove compartment just below the grab bar.
Old Sep 2, 2010 | 06:01 PM
NormalJeep's Avatar
I've been thinking about where to do this, as much as I like the drivers seat mount, I worry it will get snatched when doorless. I may try to see if I can fit it on the backside on the console. I usually leave the back doors on anyway. This way it's a little safer and still in arms reach.
Old Sep 2, 2010 | 06:20 PM
Bazetthound's Avatar
I would never use a maglite... when I can use my surefire.
I keep it in a speed holster attached to the roll bar above my head.
Old Sep 2, 2010 | 06:28 PM
USCG-JK's Avatar
Surefire is overpriced I carry 3 dollar beam from homedepot my gun rig at work just as good plus it has a laser pointer
Old Sep 2, 2010 | 06:32 PM
HIROLLR's Avatar
Get a Lens Laser flashlight. LED, very bright and small (depending on which model you choose). Light and easy to cary, hold and use. Buy a gun to replace your "weapon"........it gets mounted on your side or one of many other concealed carry options.
Old Sep 2, 2010 | 06:58 PM
another spot i've considered is the flat spots on eithe side of the console that houses the nav/temp controls. its wide enough but I need to check to see if my leg or the passengers leg would bump against it. I'm going to mount the clips with automotive 3m tape until I"m positive where its going.
Old Sep 3, 2010 | 04:57 AM
Stoneaxe's Avatar
Originally Posted by spleify
Ok, here are some pics of just the clips
Awesome idea. I had the maglite clips in my garage and my maglite tossed under the drivers seat in the Jeep. About 10 minutes after reading this post...
