Ideas for track bar brackets' reinforcement
Old Mar 23, 2011 | 08:28 AM
leolito's Avatar
Default Ideas for track bar brackets' reinforcement
I know this has been covered several times, but I failed to find an answer to this ....
(Finally!) I am ready to start the lift build - OME md - and I want to address the issue of the possible rear track bar bracket failure, before something happens (service here sucks and I am on my own for most upgrade jobs).
For the front I have a JKS adjustable track bar, so I assume (hope) will hold for a while, but for the rear I have only the OME "extension" bracket (looks similar to the Teraflex one).
A glance under the Jeep shows the original bracket still holds (only mild wheeling so far), so the first question is: can I leave it and perhaps weld some reinforcement such as the JKS brace http://www.quadratec.com/products/16007_005.htm or do I need to replace the original bracket with the JKS reinforced one: http://www.quadratec.com/products/16007_0101.htm
Now, regardless of the answer, will this setup provide some adjustability in case corrections are needed (original track bar) or should I contemplate getting a an adjustable track bar in the future?
I have seen Teraflex offers a rear bracket which does offer some possibility to make adjustments http://www.quadratec.com/products/16191_9004_07.htm would it be a better option and perhaps avoid/delay having to get an adjustable track bar? It however mentions is for +3" and I doubt that the OME coils will provide that ... what would you guys suggest?
I do not plan to lift the JK further, and for now stick to easy off roading
Thanks in advance!
Old Mar 23, 2011 | 09:01 AM
08yellowx's Avatar
Better reinforce the front one, it will fail. Checkout the factory welds they are few and far between. Luckily mine fail in a parking lot one day after returning from moab. I used some small pieces of 5/16 plate to reinforce it and tie it to the spring perch after
Rewelding all the factory welds. Keep in mind when this thing breaks most all steering is lost so I would start with the front because it has so much more pressure on it. I've had no problems with the rear.
Old Mar 23, 2011 | 09:16 AM
sacdaddy03's Avatar
If you have access to a welder. Hear nothing about good things about the JKS braces.
http://www.northridge4x4.com/proddet...rod=JKS-OGS162
http://www.northridge4x4.com/proddet...rod=JKS-OGS169
Old Mar 23, 2011 | 07:13 PM
betjeep09's Avatar
the 2nd link is a factory replacement. Why waste the money if your plan is to reenforce the stock one. Not sure how
Much lift you have.. The adjustable rear track bar is always a great option (as long as it's applicable for you setup)
Old Mar 24, 2011 | 01:29 AM
leolito's Avatar
Thanks guys! Knew I could count on ....
So the JKS 'brace' works with the oem bracket if applicable, or with the JKS replacement bracket in case the oem is trashed. Clear!
I did not know there was a brace for the front together with the relo for the steering stabilizer, I'll look into that.
I plan to run a OME md lift and have an adjustable bar for the front, most likely I will get another one for the rear, but for now I will start by having the brace welded to the oem bracket.
Old Mar 24, 2011 | 05:20 AM
tattedfire's Avatar
I would highly recommend beefing up the front track bar bracket. It's a piss poor design by jeep and I'm shocked it went into production being as thin as it is and what it's meant for
Old Mar 24, 2011 | 07:44 AM
LBJEEPER's Avatar
DO THE FRONT FIRST!!!!!!! Had mine shear off the front axle doing 85 MPH on the highway and it was definitely an experience that I can live without repeating again, and that was me wheeling on a full stock set up. My rear didn't give til after my bumpers, winch, lift and 37's and that was me with the pedal to the floor through whoops ranging from 1-3 ft deep and trying to show off. So yes re-enforce or replace both but if you have to go one at a time definitely do the front first. Nothing says lesson learned like losing almost all ability to steer at 85 MPH in Cali traffic.
