Installing Evo Drag link flip kit
Old Jul 10, 2012 | 09:44 PM
ninjajmoney's Avatar
Default Installing Evo Drag link flip kit
Like the title says... my question is, do I need to get an alignment after I do the install?
Old Jul 11, 2012 | 03:40 AM
DSOY's Avatar
I was wondering the same. Probably going to do it soon.
Old Jul 11, 2012 | 04:20 AM
archijeff's Avatar
Most likely yes, however I measured my drag link to the existing and didn't need to. There are lots of how-to on alignments that I suggest you read on this forum. If you do a lot of wheeling your alignment will constantly need to be checked. After a while you will easily be able to keep in check.
Old Jul 11, 2012 | 07:35 AM
EVO MFG's Avatar
Sponsoring Manufacturer
IF you are just installing the drag link flip, then NO. You will not need an alignment.
Old Jul 11, 2012 | 09:44 AM
69mach1's Avatar
Cool
No alignment needed, just recenter your differential with the adjustable track bar and set your steering wheel straight via the drag link adjustment
Old Jul 11, 2012 | 07:27 PM
Thanks for the quick responses.
